Lookup Behavior Properties View Nodeset Tab
Use the Properties view Nodeset tab to define the XPath expression that selects the set of nodes that comprise the lookup results. You can enter the expression or drag the desired nodes into the XPath Expression field.
Field | Use |
XPath Expression |
Enter an XPath expression. You can select a data node from the Order Template tab (when working in the Order editor), or from the Task Data tab (when working in a Task editor) and drag the selected data node into the XPath Expression field to define the XPath expression. To drag a data node into the Properties view Nodeset tab, press and hold the Alt key before you select and drag the data node to the XPath Expressions field. XPath uses path expressions to select data nodes in XML documents. A path expression with a single dot (.) represents the current node. Two dots (..) represents the parent of the current node. A slash (/) represents the root node. XPath and XQuery fields are limited to 4000 characters. |
