Design Studio Modeling OSM Processes Automation and Compensation Examples Custom Java Automation Plug-ins Custom Java Automation Plug-ins This topic provides common usage examples for custom Java automation plug-ins. Internal Custom Java Automator Internal Custom Java Sender External Custom Java Automator that Changes the OSM Task Status External Custom Java Automator that Updates Order Data Using OrderDataUpdate Elements to Pass Order Modification Data Examples of Sending Messages to External Systems Examples of Handling Responses from External Systems
