Defining Build-and-Deploy Modes for Automation Plug-ins
The information in this topic applies between the OSM 7.0.3 and 7.2.4.x releases. Design Studio uses only the Legacy build-and-deploy mode for releases before OSM 7.0.3, and uses only the Optimized build-and-deploy mode starting in OSM 7.3.
When you deploy cartridges with automation plug-ins to your OSM run-time environment (automation plug-ins for automation tasks as well as for activation tasks), you can define a configuration to have Design Studio build and deploy automation plug-ins in a particular way. Prior to OSM 7.0.3, when you built and deployed a cartridge that included automation plug-ins, OSM ran each automation plug-in in that cartridge in its own separate EAR file; this method of building and deploying automation plug-ins is now referred to as the Legacy build-and-deploy mode. Legacy mode simply refers to the manner in which automation plug-ins were deployed and processed prior to OSM 7.0.3. As of release OSM 7.0.3, you can build and deploy a cartridge in Design Studio using the Optimized build-and-deploy mode, the default mode; this mode improves the performance of processing of automated or activation tasks and improves the performance of build and deployment of cartridges with such tasks.
The Legacy build-and-deploy mode is deprecated, but it is supported for backward compatibility in OSM server versions before OSM 7.3.
XML Catalog support is required to be enabled for all cartridges as of release OSM 7.0.3.
