Studio Environment Editor Properties Tab
Use the Studio Environment editor Properties tab to review and edit the model and cartridge default variables defined for all of the cartridges in the workspace.
| Column | Use |
Name |
Displays the name of the variable. Design Studio displays all cartridge model and cartridge management variables that are defined in the workspace. |
Environment Value |
Displays the default value defined for the variable. You can select this value to change the default value to an environment-specific value. Default values are represented by blue diamond-shaped icons. |
Source Cartridge |
Displays the name of the cartridge from which Design Studio has retrieved the variable and the default value. When a variable is used in multiple cartridges, the name that appears in this column is the name of the first cartridge in which Design Studio encounters the variable. Note: When defining default values for variables, employ the same default value for a variable across all cartridges in a workspace. If a variable defined in multiple cartridges does not share the same variable value, a warning appears in the Problems view. |
