Managing Orders for Multiple Cartridge Versions
In-progress orders for an existing cartridge are not impacted by the deployment of a new version of that cartridge, nor are they automatically migrated to the new version of the cartridge. For new orders to be created by default against the new version of the cartridge, the Default option (in the Project editor Properties tab) for the cartridge should be selected before it is deployed. Orders can be targeted to previous versions of a cartridge by specifying the version numbers in the order. See the discussion of the Project editor Properties Tab in the OSM Modeling Processes Online help for more details.
It is possible to send a revision order from a newer version of a cartridge against an in-flight order from an older version of the cartridge. The order will process only data that was contained in the original cartridge metadata.
XMLIE provides scripts to migrate orders from one cartridge version to another. For details, see the discussion on migrating orders in OSM System Administrator's Guide.
When an older cartridge version is no longer needed, consider removing it from OSM. You may wish to back up completed orders associated with the cartridge before undeploying it because the completed orders may be purged from the system.
To avoid purging orders from an old cartridge, you can create a different cartridge version for modeling changes, then create and process new orders with the new cartridge namespace and version. The old orders are processed with the old cartridge version. You can also disable the creation tasks of the old cartridge to ensure that no new orders are created with the old cartridge version.
