About the Process Editor Exception Paths Drawer
Exception paths are used in conjunction with redirect and end activities to define process exceptions. Process exceptions let you alter the normal process flow from anywhere within a process (or subprocess) at any time while running the process. You can also model an exception with role restrictions, thus allowing only selected roles to throw the exception.
See "Designing Exception Paths" for more information about exception paths.
