About Print Controls
Use the following context menu options to control the Process editor printing features:
Field | Use |
Select to print a diagram or a selection of the diagram. Note: The first time that you invoke a print function, the system queries the current status of the installed printer, which may cause an initial delay. |
Print Preview |
Select to display each page to be printed and their corresponding page margins. On the Print Preview page, click the Setup button to access the Page Setup page, where you can scale the selection to fit a specific number of pages, and modify the layouts, margins, header and footers, and page order. You can access the page setup properties from Process editor context menu by selecting Page Setup. |
Print Diagram to Image File |
Select to save the image in JPG or PNG format. |
Page Setup |
Select to scale the selection to fit a specific number of pages, and modify the layouts, margins, header and footers, and page order. |
Set Print Area |
Select to print a selection of the diagram. Using the Selection tool, click and drag over the area you want included in the print. |
Clear Print Area |
Select to clear the selected print area and dismiss the selection. |
