Reviewing Design Studio Sample Cartridges
Design Studio includes two OSM sample cartridges intended to provide examples of the type of configuration that you can model in a Design Studio OSM cartridge project. You can use these sample cartridges to familiarize yourself with OSM functionality, as a reference aid when first learning Design Studio, and as a starting point when modeling OSM cartridges. Each cartridge contains corresponding documentation to describe the cartridge content.
To open and review a sample cartridge:
Install the Design Studio Samples feature from your internal update site.
For information about installing features, see the Design Studio Installation Guide.
From the File menu, select New, and then select Example.
The New Example dialog box is displayed.
Expand the Design Studio Order and Service Management Provisioning Examples directory.
Select a sample cartridge.
There are two OSM sample cartridges. Select one of the following:
Provisioning Broadband and Order Change Demo
Provisioning View Framework Demo
Click Next.
Select the example project to contain the sample cartridge.
Do one of the following:
For the Provisioning Broadband and Order Change Demo, select bb_ocm_demo.
Provisioning View Framework Demo, select view_framework_demo.
Click Finish.
The project is added to the Studio Projects view. You can expand the project directory to explore the entities included in the sample cartridge.
Access the sample cartridge documentation.
Each cartridge is delivered with a corresponding file that contains documentation to describe the cartridge functionality. To access the documentation:
From the Window menu, select Show View, and then select Package Explorer.
In the Package Explore view, expand the sample cartridge project directory.
For example, expand either the bb_ocm_demo or the view_framework_demo directory.
Expand the doc directory.
Double-click the file to open the documentation.
To run view_framework_demo in an OSM environment, you must define your Design Studio language preference as English (United States) [en-us]. See "Defining Language Preferences" for more information.
