Properties Events Automation Tab
Use the Properties Events Automation tab to configure an automation plug-in that performs the work or sends data to an external system when the notification is triggered.
Field | Use |
Add |
Click to open the Add Automation dialog box opens. |
Name |
Enter a name for the automation entry. |
Action |
Select the automation plug-in type from the available list. Click OK to add the automation entry to the Automation table. |
Properties |
Select any entry in the table and click to define the automation properties. See "Configuring Automation Plug-In Properties" for information about defining automation properties on the Properties tab. |
