Task Editor Jeopardy Automation Tab
Use the Jeopardy Automation tab to configure an automation plug-in that performs the work or sends data to an external system when the jeopardy notification is triggered. OSM supports one automation plug-in per Jeopardy.
Field | Use |
Add |
Click Add to open the Add Automation dialog box is displayed, where you can define a new automation plug-in for the jeopardy notification. |
Name |
Enter a name for the automation entry. |
Automation Type |
Select the automation plug-in type from the available list. Click OK to add the automation entry to the Jeopardy Automation table. |
Properties |
Select any entry in the table and click to define the automation properties. See "Configuring Automation Plug-In Properties" for more information about defining automation properties in the Properties view. |
