Atomic Action Editor Mappings Tab
Use the Mappings tab for mapping action processors to the atomic action.
Field | Use |
Open |
Click to open the action processor selected in the grid. |
Clone |
Click to create a copy of the action processor selected in the grid. |
Remove |
Click to clear the action processor from the grid. |
Add |
Click to map an action processor to the atomic action. The mapped action processor appears in the grid. |
Vendor, Technology, and Software Load |
Displays the vendor, technology, and software load for the selected action processor. You can select an atomic action to map to different action processors based on the vendor, technology, and software load. For example, later when the network element software version changes, you can create another action processor and map that one also to the same atomic action. As entries in the mappings cannot have duplicate vendor, technology, and software, you can update some of them accordingly. This allows you to use the same cartridge even when the software version changes. |
Action Processor |
Displays the name of the action processor selected in the grid. |
Script |
Displays the script that contains the method, as seen on the Action Processor editor, that is run for the selected action processor. |
Command Overview |
Describes the expected behavior of the action processor when the script in the Script field is called. |
