Activation Project Editor Testing Tab
Use the Testing tab to view ASAP test cases that you created for your projects and run them individually or simultaneously.
Field Use
Environment
Select a run-time environment that has configuration for an ASAP environment.
Include all from Project
Select to include all test case entities.
Entity
Displays activation test case entities.
Status
Displays the status of a work order.
Run All
Click to run all test cases one by one in the run-time environment.
Separate Console for each Test Case
Select to open a different console window for each test case in a run-time environment.
Select
Click to add a test case entity from the project.
Open
Click to open a specific test case entity.
Remove
Click to clear a specific test case entity from the Testing tab.
Run
Click to run a specific test case.
