Creating New NEP Map Entities
To create a new NEP Map entity:
Create a Studio Environment project.
See "Creating Environment Projects" in Design Studio Modeling Basics Guide for more information.
In the Studio Projects view, right-click and select New, select Environment, then select NEP Map.
The NEP Map Wizard appears.
Select a Studio Environment project from the list.
Select an environment from the Studio Environment list.
The Studio Environment list contains all of the .sceEnvironment objects in the workspace. By associating the NEP Map entity with the selected Studio environment, the entity can obtain from the environment the ASAP JMX server:port information and the ENV_ID, among other properties.
Specify an entity name.
The system applies a default entity name prefix of M_.
(Optional) Select a location for the entity.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish to create the entity in the specified location of the project.
The system creates a new .nepMap object and opens the new entity in the NEP Map editor.
