Event Template Editor
Use the Event Template editor to customize the parameters that are returned when an ASAP event is triggered. If there is no matching template for an event type, no parameters are returned. You can configure static event templates, using the editor, for just four types of events like Order Startup event, Order Complete event, Order Timeout event, and Order Fail event.
The dynamic event templates have precedence over static ones. Therefore, if there is any matching dynamic event template, no static event template will be checked. See ASAP System Administrator's Guide for more information.
Depending on the variable INCLUDE_SERVICE_ACTION_DETAIL, the service action parameters are returned. See the ASAP Server Configuration Guide for more information.
In the Studio Projects view, double-click an event template entity to open the Event Template editor. You can create the editor using the Event Template Wizard.
When working with the Event Template editor, see the following topics:
