Service Bundle Editor Service Actions Tab
Use the Service Actions tab to associate service action entities with the service bundle and define conditions to spawn the service actions.
Service Bundle Details
| Field | Use |
Remove |
Click to remove a service action from this tab. |
Add |
Click to add a service action to this tab. |
Service Action Condition
| Field | Use |
Always |
Select for ASAP to always spawn this service action for this service bundle. Always is selected by default when you add a service action to the Service Bundle editor. |
Equals |
Select for ASAP to spawn this service action only if the specified service action parameter, in the Parameter Label field, is defined on the service action and has a parameter value as defined in the Parameter Value field. |
Defined |
Select for ASAP to spawn this service action only if the service action parameter specified in the Parameter Label field is defined on the service action. |
Not Defined |
Select for ASAP to spawn this service action only if the service action parameter specified in the Parameter Label field is not defined on the service action. |
Parameter Label |
Select a label name from the list. |
Parameter Value |
Specify a value in the field. This field is available when you select the Equals button. |
Include Expression |
Define a logical expression using a number of criteria. The range of options available allows a service action to be processed if the service action parameter value is within a set range of values, or if the service action parameter is greater than, less than, or equal to, a specified value. You can combine multiple expressions using an AND or OR operator. See "About Service Action Spawning Conditions" for more information. |
Related Topics
