Action Editor Action Codes Tab
Use the Action Codes tab to review the action codes associated with an action, to add new action codes, to remove action codes that are not applicable, and to edit specialized action code names.
Field | Use |
Application Role |
Displays the name of the application role that represents a specific type of downstream delivery system. The application role characterizes the technical action family and the specialized action code names that are associated with a specific edge fulfillment system. Design Studio includes a set of predefined application roles. Click the Application Role link to open the application role in the Application Role editor. |
Specialized Action Code |
Displays the list of action codes associated with the action. The list that initially appears is inherited from the associated application role. You can add or remove Specialized Action Name and Action Code pairs. The action codes available to add to the action are defined on the functional area associated with the application role (specified in the Action Type field). For example, when modeling technical actions, you can add any action code defined on the Technical functional area. |
Specialized Action Code Details |
(Technical actions only) In the Specialized Action Name field, you can edit the value to ensure that the Specialized Action Name is specific to the application role and to the fulfillment system to which the name is relevant. Click the Action Code link to open the action code in the Action Code editor. |
