Defining Project Version Numbers
After you create a project, you define the version number. You can change the version at a later time. When changing the version of deployable cartridge projects, clean and build the project (and any dependent projects) before deploying the cartridge projects or the dependent cartridge projects.
To define a project version number:
In the Studio Projects view, double-click any Project entity.
The entity opens in the Project editor.
Click the Properties tab.
Enter values for the Major Version Number, Minor Version Number, Maintenance Pack, Generic Patch, and Customer Patch fields.
The combination of these version numbers (with the value in the Build field, which is automatically generated) represents the cartridge version number. Some cartridges support 3 digit version numbers (using Major Version Number, Minor Version Number, and Maintenance Pack). Version support is determined by the Design Studio feature and by the selected target version. See "Product Editor Properties Tab" for more information about these fields.
Select File, then select Save.
