Adding Model Collections to Network Integrity Actions
Adding a model collection to an action allows the action to use the specifications contained in the model collection from other cartridge projects.
By default, when you create an action, all model collections in the same cartridge project are automatically added to the action. You should add only new model collections to an action.
To add a model collection to an action:
On the Action editor Model tab, click Add.
The Select the Model Collection to Add dialog box appears.
From the Matching Items list, select the model collection.
You can filter the Matching Items list by typing in the Select an item to open field.
Click OK.
Design Studio adds the model collection to the action.
Save the action.
