Adding Output Parameters to Network Integrity Processors
To add output parameters to a processor:
On the Processor editor Context Parameter tab, in the Output Parameters area, click Add.
The Create Output Parameter dialog box appears.
In the Parameter Name field, enter a name for the parameter.
From the Parameter Type list, do one of the following:
Select a primitive type.
Click Browse and select an existing qualified Java class name.
Enter a valid and available Java object. This value is automatically validated to ensure that it is a valid Java object type.
Enter a Java generic. For example, java.util.primitive<String>.
(Optional) In the Description field, add information about the parameter.
Click OK.
Design Studio generates the Request and Response Java classes.
