Defining UI Settings for Network Integrity Scan Parameter Group Characteristics
You define the UI settings for each characteristic on a scan parameter group to determine how the characteristic appears and behaves on the Network Integrity UI. Repeat the procedure for all scan parameter group characteristics. You can assign settings and values to characteristics that you do not want to have appear in the Network Integrity UI.
To define UI settings for a characteristic:
On the Scan Parameter Group editor Layouts tab, in the Panels / Elements area, select a characteristic.
The configurable options for the characteristic appear in the UI Settings area.
Configure the following UI settings:
In the Display Name field, enter the field name as you want it to appear in the Network Integrity UI.
In the ToolTip field, enter a tooltip value for the field, to appear when a user selects the field in the Network Integrity UI.
All other fields inherit their values from the data schema.
Save the scan parameter group.
