Defining UI Settings for Network Integrity Specification Characteristics
You define the UI settings for each characteristic on a specification to determine how it appears in the Network Integrity UI scan results. Repeat the procedure for all characteristics appearing in the UI.
To define UI settings for a characteristic:
On the Specification editor Layouts tab, from the Selected list, select a characteristic.
The configurable options for the characteristic appear in the UI Settings area.
Configure the following UI settings:
In the Display Name field, enter the field name as you want it to appear in the Network Integrity UI.
In the ToolTip field, enter a tooltip value for the field, to appear when a user mouses over the field in the Network Integrity UI.
All other fields inherit their values from the data schema.
Save the specification.
