Style Behavior Properties View Appearance Tab
Use the Properties view Appearance tab to define attributes that control the appearance of a given node in the web client.
The Appearance tab is rendered differently based on whether the behavior is defined for an element or a structure. For an element, all fields are enabled except Locate in, which deals with page layouts for structures. For a structure, all fields are disabled except Locate in.
Field Use
Appearance
Select a value to control the appearance of the node based on one of the following selections:
  • Default: Uses the default node appearance
  • Compact: A fixed number of choices are rendered, with scrolling facilities, as needed
  • Full: All choices are rendered at all times
  • Minimal: A minimum number of choices are rendered, with the ability to temporarily render additional choices
Locate in
Specifies the page on which the group is placed. New Page locates the group in a newly created page, without a title.
Place on New Line
Select to place the node at the start of a new line and to define a condition under which the line break is inserted.
Make it a Password Field
Select to protect the contents of nodes containing sensitive information and to define a condition under which the field is secret.
