Order Jeopardy Editor Automation Tab Details Subtab
Use the Order Jeopardy editor Automation tab, Details subtab to provide information about the automation to trigger if the order jeopardy is raised.
Field Use
Name
Enter a plug-in name. The name must be unique among plug-in entities in the same namespace.
Note: While plug-in names can be any arbitrary name that you assign to the automation, Oracle recommends that you use a consistent naming pattern for all of the automations that you create.
Run As
Enter the OSM user name (security principal) whose credentials are used to process this automation plug-in. A password is not necessary to authenticate this user because only an administrator has the authority to deploy components into the server.
The value of this field must reflect the user ID that is used to run the automation:
  • The user ID must be set up in the WebLogic Server Administration console. See the discussion of setting up security in OSM System Administrator's Guide for more information.
  • The user ID must be defined in the OSM Administration area of the Order Management web client (a workgroup in OSM Administration is a role in Design Studio). See "Working with Roles" for more information.
  • The user ID must be assigned to the workgroup in the OSM Administration area of the Order Management web client that corresponds to the role defined on the Permissions tab of the Design Studio task, order, or process that defines the automation.
Note: Oracle recommends using the DEFAULT_AUTOMATION_USER cartridge model variable in the Run As field. See "Defining Model Variables" for more information.
