Redirect Properties General Tab
Use the Redirect Properties General tab to define to which process and to which task within that process you want the order redirected.
Field | Use |
Reference |
Select the process to which you want the order redirected. To select the process, click inside the Value field to access the ellipsis button. Click the ellipsis button and select a process from the entity list. Note: After you define the Reference process, you can double-click the Redirect entity to open the process in the Process editor. |
Reference Task |
Select the task to which you want the order redirected. When you specify a process in the Reference field, you can also redirect to a specific starting point within that process. The process will run to completion from the task that you select here. If you select no task here, the process will start with the first task. |
X, Y coordinates |
These coordinates indicate where on the Process editor canvas the Redirect activity exists. |
