Order Lifecycle Manager Editor Properties Tab
Use the Properties tab to set the properties and presentation-level information, such as Customer Name and Customer ID, for the Order Lifecycle Management UI. You can define, per role and view, where in the order the values for those fields come from. In the Order Lifecycle Management UI, users belonging to a specified role see values for Customer Name and Customer ID as extracted from fields with the associated view.
See "Order Lifecycle Manager Editor" for information about fields that appear on both Fulfillment Pattern editor tabs.
| Field | Use |
Order |
Click Select and select the order to which this order lifecycle manager applies. This field is mandatory if you are defining an order summary binding (that is, if you are defining properties for an order) in this order lifecycle manager. If you are only using this order lifecycle manager to define the state mappings, it is optional. If you do not select a value for this field, the configuration of this entity applies to all orders. |
Roles |
Specify the roles that require access to the order. Do any of the following:
Role |
Displays the role selected in the Roles table. Click Select to select a different role. |
View |
The view associated with the role selected in the Roles table. Click Select to select a different view. |
Order Summary Headers area |
Select the data elements that contain the header information to use in the Order Lifecycle Management UI. All data elements you select must be in the view specified in the View field. Users with the role selected in the Roles table will see the values obtained from these data elements. Select a role in the Roles table and do any of the following:
Additional Properties |
(Optional) Specify additional properties to send to the Order Lifecycle Management UI. Do any of the following:
Name |
Displays the property selected in the Additional Properties table. Click Select to select a different property. |
Path |
Displays the path associated with the data element to use. The data element must be in the view displayed in the View field. Click Select to select a different data element. |
