Target Network Elements Tab
Use the Target Network Elements tab to define the target network elements to which you can route atomic actions.
| Field | Use |
Target Network Element, Atomic Action, and Description |
Displays the values configured in the Target NE Details area. |
Add |
Click to add a new target network element. |
Remove |
Click to clear a target network element from the editor. |
Target NE Name |
Specify the name of a target network element to which you can route an atomic action. |
Select |
Click to select an atomic action to be routed through the target network element. Do not select a specific atomic action, if you want all the atomic actions to be routed to one network element. |
Clear |
Click to clear the atomic action for a specific target network element. |
Description |
Specify a description for the target network element. |
