All Communication Parameters Tab
Use the All Communication Parameters tab to define the global communication parameters. The global communication parameters are common to all the connections in a connection pool.
The local communication parameters appear in this tab but are not editable. These are the same as can be seen in the Connections tab for a specific connection.
You can double-click and edit only the global communication parameters.
| Field | Use |
Parameter Label |
Displays the name of the communication parameter. You can double-click to rename the parameter label name. |
Connection |
Displays the connection as global or local. If the parameter is local, the connection name of the connection to which the parameter belongs appears. |
Value |
Double-click to specify a value to the global communication parameter. |
Description |
Double-click to specify a description to the global communication parameter. |
Add Global |
Click to add a parameter as global. |
Remove Global |
Click to clear a parameter from the editor. |
