General System Information
This section explains the parameters that encompass the general system information on a Oracle Communications Session Border Controller.
System Identification
Global system identification is used primarily by the Oracle Communications Session Border Controller to identify itself to other systems and for general identification purposes.
Connection Timeouts
It is important to set administrative session timeouts on the Oracle Communications Session Border Controller for security purposes. If you leave an active configuration session unattended, reconfiguration access is left open to anyone. By setting a connection timeout, only a short amount of time needs to elapse before the password is required for Oracle Communications Session Border Controller access.
Timeouts determine the specified time period that must pass before an administrative connection is terminated. Any subsequent configuration activity can only be performed after logging in again to the Oracle Communications Session Border Controller. The timeout parameter can be individually specified for SSH sessions and for console port sessions.
After the SSH timeout passes, the SSH session is disconnected. You must use your SSH program to log in to the Oracle Communications Session Border Controller once again to perform any further configuration activity.
After the console timeout passes, the console session is disconnected. The current session ends and you are returned to the login prompt on the console connection into the Oracle Communications Session Border Controller.
Cluster Member Graceful Shutdown
When it becomes necessary to temporarily remove an SBC from active service, and make it available only for administrative purposes, the user issues a set-system-state offline ACLI command. The SBC begins a graceful shutdown. The shutdown is graceful in that active calls and registrations are not affected, but new calls and registrations are rejected except as discussed below. When the user issues the command, the SBC goes into becoming offline mode. Once there are no active SIP sessions and no active SIP registrations in the system, the SBC transitions to offline mode. If the SBC is a member of a cluster, the offline status is communicated when the user issues the set-system-state offline command, and the SBC excludes the offline SBC in future endpoint (re)balancing algorithms.
The graceful shutdown procedure is limited only to SIP calls and registrations.
Detailed Description of Graceful Shutdowns with Active SIP Calls or Registrations
This is the procedure when active SIP calls or registrations are on an SBC.
When the system receives the set-system-state offline command, it transitions to becoming offline mode. It begins checking the number of SIP-INVITE-based sessions and the number of SIP registrations, and continues to check them when sessions complete or registrations expire while it is in becoming offline mode. When both counts reach zero, the system transitions to offline mode. If the system is a member of a Subscriber-Aware Load Balancer cluster, the Subscriber-Aware Load Balancer client on the SBC changes its cluster status to the shutdown state, and informs the Subscriber-Aware Load Balancer that it is offline. The Subscriber-Aware Load Balancer ceases to forward new end-points to the SBC and lists the SBC in a shutdown state on the Subscriber-Aware Load Balancer. The SBC continues to send heartbeat updates to the Subscriber-Aware Load Balancer as before.
Active calls continue normally when the SBC is in becoming offline mode. If SIP refresh registrations arrive for endpoints that have active calls, they are accepted. However, the expiry of these endpoints is reduced to the configurable retry-after-upon-offline timer value (in seconds) defined under sip-config on the SBC. This timer should be configured to be a much lower time interval than originally requested by the refresh registrations, so that endpoints refresh sooner and thus the registrations expire as closely as possible to when the active call ends. If the new timer value configured in retry-after-upon-offline is greater than the existing registration requested refresh value, or if its value is ‘0’ (unconfigured), the original registration refresh request is honored.
Refresh registrations for endpoints that do not have any active calls are rejected with a configurable response code defined in the sip-config reg-reject-response-upon-offline parameter. The default for this parameter is the 503 Service Unavailable message. The default for this parameter is the 503 Service Unavailable message and includes a Retry-After header with a configurable timer set in retry-after-upon-offline. Note that if this value is set to 0, the SBC returns Retry-After:0, which means immediately. Once these refreshes are rejected, SBC immediately removes such endpoints from its registration cache. It is a force remove. De-registrations are forwarded to the core. There is no local response. Removals are communicated to the Subscriber-Aware Load Balancer.
Any new calls that arrive for endpoints that currently have registration entries are not rejected. The same retry-after-upon-offline action is performed.
Any other SIP methods (like SUBSCRIBE or MESSAGE) intended for this endpoint is handled normally and are not rejected. Priority calls are processed as usual by the SBC, regardless of whether an active registration is present in the SBC as long as the SBC is in becoming offline state. When the SBC transitions to the offline state, even priority calls are rejected. If the priority calls cannot be forwarded to the endpoint, a 380 Alternative Service response may be sent, depending on the SBC's configuration. However, when the SBC achieves offline mode, even priority calls are rejected. New non-priority calls coming for endpoints that are not currently registered are rejected with the 503 Service Unavailable error message, as has always been done.
The SBC sends the endpoint removal requests to the Subscriber-Aware Load Balancer so that the Subscriber-Aware Load Balancer removes them from its endpoint table. If a REGISTER message comes in with multiple contacts, it’s possible that one of the contacts has an active call while others do not. In that scenario, the contact without active call has the Expires value in the Contact header changed to 0 and is forwarded to the core. When the response arrives from the core, the Contact with active call has its Expires parameter modified to the retry-after-upon-offline value or the UA expires value, whichever is lower. Any contact with no active calls is removed from the cache.
Eventually, all SIP calls end, and all registrations expire. The SBC transitions to the offline system state. The SBC continues to send heartbeat updates to the Subscriber-Aware Load Balancer.
At any time after the issuance of the set-system-state offline command, a set-system-state online command may be issued. If the SBC is in becoming offline mode, the process is aborted and the SBC again becomes online. The SBC state is forwarded to the Subscriber-Aware Load Balancer, and the SBC once again participates in the Subscriber-Aware Load Balancer's (re)balancing process.
High-level Procedure for Graceful Shutdown
This section describes the graceful shutdown procedure. Details and exceptions to this procedure when there are active calls or registrations are discussed in later paragraphs. The first six actions are performed regardless of whether or not the SBC is part of an Oracle Communications Subscriber-Aware Load Balancer Cluster
  • The SBC receives the set-system-state offline command.
  • The SBC transitions to becoming offline mode.
  • The SBC accepts calls and subscribes from registered endpoints.
  • The SBC rejects calls from non-registered endpoints.
  • The SBC rejects new registrations with a 503 Service Unavailable error message.
  • The SBC checks the number SIP INVITE based sessions and number of SIP registrations. When both counts are 0, the SBC transitions to the offline state.
Previous versions only looked at active SIP sessions (calls), without monitoring active SIP registrations.
If the SBC is part of an Subscriber-Aware Load Balancer cluster:
  • The Subscriber-Aware Load Balancer client on the SBC changes its cluster status to shutdown state.
  • The SBC informs the Subscriber-Aware Load Balancer that it is offline.
  • The Subscriber-Aware Load Balancer ceases to forward new end-points to the SBC and puts the SBC in a shutdown state.
  • Subscriber-Aware Load Balancer continues to forward all messages for existing registered endpoints to the offline SBC.
  • The SBC continues to send heartbeat updates the Subscriber-Aware Load Balancer as before.
