40GB or More Default Format Plan
When formatting a storage device larger than 40 GB, /mnt/sys and /mnt/app volumes are created in the data partition. Their relative sizes are based on the drive’s size.
Table 9-2 System Format Plan (40 GB +):
| Volume Number | Volume Name | Volume Size |
| system partition | /opt | 8 GB |
| data partition | /mnt/sys | 20% remaining space |
| data partition | /mnt/app | 80% remaining space |
