9 Formatting the Disk Volume
After the system has booted the Oracle Communications product for the first time, the hard disk must be formatted from the application. Remember that, at the chassis level, the disk system must be presented as a single logical drive.
For systems without a separate boot flash, the format system-disk command combines the /opt and /opt/crash into a single system partition if they are separate partitions. This includes all systems other than the Acme Packet 4600, 6100 and 6300.
