Import a Certificate Using the ACLI
After the Certificate Authority (CA) generates the certificate, you can import it into the Oracle Communications Session Border Controller (OCSBC) with the import-certificate command.
Use the following syntax:
ORACLE # import-certificate [try-all|pkcs7|x509] [certificate-record file-name]
