TSCF Management Monitoring
- TSCF global statistics
- address pool usage
- tunnel creation and state
TSCF Global Statistics
The show tscf statistics brief command displays summary TSCF global data.
ORACLE# show tscf statistics brief
22:08:16-133
Tunnel Capacity=200000
-- Period -- ----- Lifetime ------
Active High Total Total PerMax High
Established Tunnels 0 0 0 0 0 0
22:08:16-133
TSCF Statistics ----- Lifetime ------
Recent Total PerMax
Tunnel Adds 0 0 0
Tunnel Rejects 0 0 0
Tunnel Deletes 0 0 0
Tunnel Errors 0 0 0
ORACLE#
The show tscf statistics command displays verbose TSCF global data.
22:08:02-119
22:08:02-119
TSCF Statistics ------ Lifetime -------
Recent Total PerMax
Tunnel Adds 0 0 0
Tunnel De1etes 0 0 0
Tunnel Errors 0 0 0
Active Tunnels : 1500
Established Tunnels : 1500
Finished Tunnels : 0
Released Tunnels : 1500
Max Active Tunnels : 0
Failed Tunnels - Malformed Request : 0
Fai1ed Tunnels - Non Existing Tunnel Id : 0
Fai1ed Tunnels - Out of Resources : 0
Fai1ed Tunnels - Server Failure : 0
Fai1ed Tunnels - Version Not Supported : 0
ORACLE#
Address Pool Statistics
ORACLE# show tscf address-pool all
# |Addr Pool Name |Total |In Use |Free |Invalid |
1 |pool1 |65279 |1500 |63779 |0 |
ORACLE#
The show tscf address-pool <addressPoolName> command displays data for a single specified address pool.
ORACLE# show tscf address-pool pool1
ORACLE#
Tunnel Statistics
The show tscf tunnel all command displays basic summary information for each tunnel.
ORACLE# show tscf tunnel all
# | Tunnel Id | Inner IP | Outer IP |St |
1| 0000000100000042| 10.10.0.66| 192.168.50.77| A |
2| 0000000100000043| 10.10.0.67| 192.168.50.77| A |
ORACLE#
The show tscf tunnel all detailed command displays verbose information for each tunnel.
ORACLE# show tscf tunnel all detailed
Prot = Protocol
Att = Attributes. [6 Attributes]
[R = Redundancy # = RedundacyFactor, P = Primary, D = DDT, S = Server Initiated Keepalive/C= client Initiated Keepalive, T/F = Nagle On(T)/Off(F)
H = Created on Standby]
Creation time and date (mm/dd/yy)
T1 = Time (seconds) since last data packet received from TSC
T2 = Time (seconds) since last data packet sent on TSC
T3 = Time (seconds) since last control message received from TSC
T4 = Time (seconds) since last control message sent on TSC
T5 = Time (seconds) in current state (Active or Persistent)
St = State [S=Start No=NoSession I=Init Ne=Negotiating A=Active P=Persistent R=Released]
RC = Reconnect count
# | Tunnel Id | Inner IP | Outer IP : Port |...
1| 0000000100000042| 10.10.0.66| 192.168.50.77: 43354|...
2| 0000000100000043| 10.10.0.67| 192.168.50.77: 54458|...
ORACLE#
The show tscf tunnel peer-inner-ip <ipAddress> command displays summary information for a specific tunnel identified by its IP address as assigned from an address pool.
ORACLE# show tscf tunnel peer-inner-ip 10.10.0.66
ORACLE#
The show tscf tunnel peer-outer-ip <ipAddress> command displays summary information for a set of tunnels emanating from the specified client interface address.
ORACLE# show tscf tunnel peer-outer-ip 192.168.50.77
ORACLE#
The show tscf tunnel state <state> command displays basic tunnel data for all tunnels in the specified state.
<state> can take one of the following values: Established, Finished, Negotiating, NoSession, Released, Start, Unassigned.
ORACLE# show tscf tunnel state Active
ORACLE#
The show tscf tunnel tscf-interface <realmID> command displays basic tunnel data for all tunnels supported by a TSCF port. The TSCF port is identified by the name of its supporting realm.
ORACLE# show tscf tunnel tscf-interface access
ORACLE#
The show tscf tunnel tunnel-id <tunnelID> command displays basic tunnel data for a specific tunnel identified by its tunnel ID.
A tunnel ID is assigned by the TSC server during the configuration exchange, and can be most easily obtained with the show tscf tunnel all command.
ORACLE# show tscf tunnel tunnel-id 0000000100000042
ORACLE#
Tunnel Deletion
ACLI CLI commands provide the ability to delete an individual tunnel, a group of tunnels, or all tunnels.
Use the clear-tunnel tscf all command to delete all tunnels.
ORACLE# clear-tunnel tscf all
WARNING: This will clear all tunnels and may cause service outage!!
Clear all TSCF tunnels ? [y/n]?: y
Command was successful. Deleted 1502 TSCF tunnels.
ORACLE#
Use the clear-tunnel tscf interface ... command to delete a group of tunnels.
This command deletes all tunnels on a specified interface
ORACLE# clear-tunnel tscf M1:1
Command was successful. Deleted 753 TSCF tunnels.
ORACLE#
This command deletes all TLS tunnels on a specified TSCF port
ORACLE# clear-tunnel tscf M1:1 tls 192.168.11.22:5060
WARNING: This will clear all tunnels on this port and may cause
service outage!!
ORACLE#
This command deletes all DTLS tunnels on a specified TSCF port
ORACLE# clear-tunnel tscf M1:1 dtls 192.168.11.22:5060
service outage!!
Command was successful. Deleted 226 TSCF tunnels.
ORACLE#
This command deletes all TCP tunnels on a specified TSCF port
ORACLE# clear-tunnel tscf M1:1 tcp 192.168.11.22:5060
service outage!!
Command was successful. Deleted 10 TSCF tunnels.
ORACLE#
This command deletes all UDP tunnels on a specified TSCF port
ORACLE# clear-tunnel tscf M1:1 udp 192.168.11.22:5060
service outage!!
ORACLE#
Use the clear-tunnel tscf tunnel-id ... command to delete a single tunnel.
ORACLE# clear-tunnel tscf tunnel-id feed3eef000000cf
WARNING: This will clear this tunnel and may cause service outage!!
Clear this TSCF tunnels ? [y/n]?: y
Command was successful. Deleted 1 TSCF tunnels.
ORACLE#
