Connect ILOM to the Oracle X7-2
Use the following procedure to make a connection to the Oracle X7-2 Oracle Integrated Lights Out Manager (ILOM) port. For a remote permanent connection to the Service Processor over the ILOM connection, use the rear panel NET MGT port.
Keep Ethernet cables separated from power cables by at least 60mm where possible and never run them in the same channel of the rack without segregation.
  • Category 6 (or better) Ethernet
  1. Locate the cable to connect to the Oracle X7-2 for Communications.
  2. Plug the RJ-45 connector into the ILOM port.
    Figure 3-15 Connecting to ILOM over the Network
  3. Lead the cable neatly away from the rear panel.
  4. Connect the other end of the cable to the LAN.
