5 Virtual Machine Platforms
Oracle distributes virtual machine templates, each containing a virtual disk image and default configuration for the supported profile of each VM platform. VM platform support is dependent on your Oracle product version.
This section addresses requirements associated with running applicable software as virtual machines. It also provides basic instructions on loading and starting machine templates.
VM distributors maintain extensive documentation sites. You must use those vendors' documentation for full explanations and instructions on VM deployment and operation.
