Stopping a Remote Packet Trace
You stop a remote packet trace by entering the appropriate ACLI command with these pieces of information:
- Network interface (name:subport ID combination)
 - IP address to be traced
 - (Optional) Local UDP/TCP port on which the Oracle Communications Session Border Controller sends and receives traffic to be traced
 - (Optional) Remote UDP/TCP port to which the Oracle Communications Session Border Controller sends traffic, and from which it receives traffic to be traced
If the packet trace you want to stop has no entries for local and/or remote ports, then you do not have to specify them.
