Diversion and History-Info Headers Interworking Configuration
You can configure Oracle Communications Session Border Controllers to map call transfer and call diversion information between Diversion and History-Info headers.
To configure interworking between the Diversion and History-Info headers:
  1. Access the sip-interface configuration element.
    ORACLE# configure terminal
    ORACLE(configure)# session-router
    ORACLE(session-router)# sip-interface
    ORACLE(sip-interface)#
  2. Select the sip-interface object to edit.
    ORACLE(sip-interface)# select
    <RealmID>:
    1: realm01 172.172.30.31:5060
    selection: 1
  3. diversion-info-mapping-mode— Configure this parameter to specify how the Diversion and History-Info headers map to and work with each other on the interface. The default value is none.
    • div2hist — any Diversion headers in the initial INVITEs going out of this sip-interface will be converted to History-Info headers before sending
    • force — behavior is the same as div2hist when a Diversion header is present in the incoming INVITE. If there are no Diversion headers, a History-Info header for the current URI is added in the outgoing INVITE.
    • hist2div — any History-Info headers in the initial INVITEs going out of this sip-interface will be converted to Diversion headers before sending
    • none — no conversion applied (default)
  4. Type done to save your configuration.
