Configuring Graceful Call Control
You can enable the Oracle Communications Session Border Controller to stop receiving session-initiating traffic on a media interface when the traffic for the interface exceeds the critical threshold you define for it.
To enable graceful call control:
  1. In Superuser mode, type configure terminal and press Enter.
    ORACLE# configure terminal
    ORACLE(configure)#
  2. Type system and press Enter.
    ORACLE(configure)# system
    ORACLE(system)#
  3. Type phy-interface and press Enter. If you are adding this feature to an existing configuration, then remember you must select the configuration you want to edit.
    ORACLE(system)# phy-interface
    ORACLE(phy-interface)#
  4. overload-protection—Change this parameter’s value to enabled if you want to turn graceful call control on. Leave it set to disabled (default) if you do not want to use this feature.
  5. Save your work.
