Operations Monitor Statistics
The Oracle Communications Session Border Controller (SBC) collects statistics about the operations of its communications monitor probe, which provides protocol traffic information to the Operations Monitor. You can display information about the connections to the Operations Monitor servers using the show comm-monitor command.
The show comm-monitor command displays the following types of aggregated statistics for all clients:
- Client State
- Socket Statistics
- Other Aggregate Statistics
The SBC show comm-monitor command also shows the Lifetime statistics. The command runs without or with arguments. For example,
- show comm-monitor—Shows client connection states and aggregate stats
- show comm-monitor by-client <IP-Addr>—Shows client stats
- show comm-monitor errors—Shows errors captured by the Operations Monitor
- show comm-monitor internal—Shows SBC traffic-specific counters
The following example shows show comm-monitor output without arguments:
ORACLE# show comm-monitor
Client State PROTOCOL
192.168.42.10:4739 Out-of-Service TCP
192.168.42.11:4739 Connecting TCP
192.168.42.12:4739 In-Service TCP
15:06:10-35 (recent)
CommMonitor Socket Statistics --- Lifetime ---
Recent Total PerMax
Socket Message Dropped 0 0 0
Socket Send Error 0 0 0
Socket Not Ready 0 0 0
Socket Timeouts 0 0 0
Socket Disconnects 0 0 0
Socket Reconnects 0 0 0
Buffer Allocation Error 0 0 0
CommMonitor Statistics --- Lifetime ---
Recent Total PerMax
Handshake Msg Sent 0 0 0
Handshake Msg ACK 0 0 0
Handshake Msg NAK 0 0 0
Keep Alive 0 0 0
SIP UDP Recv Msg Sent 0 0 0
SIP UDP Send Msg Sent 0 0 0
SIP TCP Recv Msg Sent 0 0 0
SIP TCP Send Msg Sent 0 0 0
SIP SCTP Recv Msg Sent 0 0 0
SIP SCTP Send Msg Sent 0 0 0
ENUM Recv Msg Sent 0 0 0
ENUM Send Msg Sent 0 0 0You can set all comm-monitor statistics to zero using the reset comm-monitor command.
