AMR-NB and AMR-WB Specifications
The Oracle Communications Session Border Controller supports Adaptive Multi-Rate Narrow Band & Wide Band codecs. All configurations of this codec, as indicated by SDP, are transcodable except when the following SDP parameters are enabled:
  • robust-sorting
  • interleaving
  • CRC
When AMR is configured in a codec policy’s add-codecs-on-egress parameter, it is forwarded from the Oracle Communications Session Border Controller with the following default settings:
  • 12.2 kbps (AMR-NB)
  • 23.85 kbps (AMR-WB)
  • RTP/IF1 format
  • No redundant packets
  • bandwidth efficient default payload
  • No CRC frame
  • 20ms default ptime
