Configure HTTP Connection Management
To prevent system issues caused by HTTP client traffic:
- In Superuser mode, type configure terminal and press Enter.
ORACLE# configure terminal
- Type system and press
Enter.
ORACLE(configure)# system ORACLE(system)#
- Type system-config and
press Enter.
ORACLE(system)# system-config ORACLE(system-config)#
If you are adding support for this feature to a preexisting configuration, you must select (using the ACLI select command) the single instance system-config element.
- httpclient-max-total-conn—Set this parameter to
specify the maximum number of TCP connections that the
http-client allows open simultaneously or disable the
function. You cannot configure httpclient-max-total-conn
in real time. You must reboot the system whenever you make a change.
Valid Values:
- 0—Disables the function
- Range—0 - 2147483647
- Default—500
ORACLE(system-config)# httpclient-max-total-conn 1000
- httpclient-max-cpu-load—Set this parameter to specify
the maximum percentage of CPU consumed by HTTP traffic during STIR/SHAKEN
operations. You cannot configure httpclient-max-cpu-load
in real time.
Valid Values:
- Range—30% - 90%
- Default—70%
ORACLE(system-config)# httpclient-max-cpu-load 60
- httpclient-cache-size-multiplier—Specifies the
multiplier used to calculate the size of the HTTP client connection cache. The
system maintains an HTTP connection cache pool. The size of the HTTP connection
cache is the number of pending transactions, multiplied by this
httpclient-cache-size-multiplier.
Valid Values:
- Default: 16
- Values: 4 - 50
ORACLE(system-config)# httpclient-cache-size-multiplier 20
