Extended PANI SIP Header
The Oracle Communications Session Border Controller provides an extended PANI header as defined in 3GPPTS 24.229, IP multimedia call control protocol based on Session Initiation Protocol (SIP) and Session Description Protocol (SDP); Stage 3.
Extended PANI header syntax is as shown below.
P-Access-Network-Info  = “P-Access-Network-Info” HCOLON
                                 access-net-spec *(COMMA access-net-spec)
access-net-spec                = (access-type / access-class) *(SEMI access-info)
access-type                    = "IEEE-802.11" / "IEEE-802.11a" / "IEEE-802.11b" / "IEEE-802.11g" /
                                 "IEEE-802.11n" / "3GPP-GERAN" / "3GPP-UTRAN-FDD" / "3GPP-UTRAN-TDD" /
                                 "3GPP-E-UTRAN-FDD" / "3GPP-E-UTRAN-TDD" / "ADSL" / "ADSL2" / "ADSL2+" /
                                 "RADSL" / "SDSL" / "HDSL" / "HDSL2" / "G.SHDSL" / "VDSL" / "IDSL" /
                                 "3GPP2-1X" / "3GPP2-1X-Femto" / "3GPP2-1X-HRPD" / "3GPP2-UMB" /
                                 "DOCSIS" / "IEEE-802.3" / "IEEE-802.3a" / "IEEE-802.3e" / "IEEE-802.3i" /
                                 "IEEE-802.3j" / "IEEE-802.3u" / "IEEE-802.3ab"/ "IEEE-802.3ae" /
                                 "IEEE-802.3ah" / "IEEE-802.3ak" / "IEEE-802.3aq" / "IEEE-802.3an" /
                                 "IEEE-802.3y" / "IEEE-802.3z" / GPON/ XGPON1 / "GSTN"/ "DVB-RCS2"
                                 "3GPP-NR-FDD" / "3GPP-NR-TDD" / token
access-class                   = "3GPP-GERAN" / "3GPP-UTRAN" / "3GPP-E-UTRAN" / "3GPP-WLAN" / "3GPP-GAN" /
                                 "3GPP-HSPA" / "3GPP2" / "3GPP-NR" / token
np                             = "network-provided"
access-info                    = cgi-3gpp / utran-cell-id-3gpp / dsl-location / i-wlan-node-id / ci-3gpp2 /
                                 ci-3gpp2-femto / eth-location / fiber-location / np/ gstn-location /
                                 local-time-zone / dvb-rcs2-node-id / extension-access-info
extension-access-info          = generic-param
cgi-3gpp                       = "cgi-3gpp" EQUAL (token / quoted-string)
utran-cell-id-3gpp             = "utran-cell-id-3gpp" EQUAL (token / quoted-string)
i-wlan-node-id                 = "i-wlan-node-id" EQUAL (token / quoted-string)
dsl-location                   = "dsl-location" EQUAL (token / quoted-string)
eth-location                   = "eth-location" EQUAL (token / quoted-string)
fiber-location                 = "fiber-location" EQUAL (token / quoted-string)
ci-3gpp2                       = "ci-3gpp2" EQUAL (token / quoted-string)
ci-3gpp2-femto                 = "ci-3gpp2-femto" EQUAL (token / quoted-string)
gstn-location                  = "gstn-location" EQUAL (token / quoted-string)
dvb-rcs2-node-id               = "dvb-rcs2-node-id" EQUAL quoted-string
local-time-zone                = "local-time-zone" EQUAL (token / quoted-string)
