40GB or More Default Format Plan
When formatting a storage device larger than 40 GB, /mnt/sys and /mnt/app volumes are created in the data partition. Their relative sizes are based on the drive’s size.
Table 10-1 System Format Plan (40 GB +):
Volume Number Volume Name Volume Size
system partition /opt 8 GB
system partition /opt/crash 2 x RAM size (not less than 8 GB)
data partition /mnt/sys 20% remaining space
data partition /mnt/app 80% remaining space
