Connect ILOM to the Oracle Server X9-2
Use the following procedure to make a connection to the Oracle Server X9-2 Oracle Integrated Lights Out Manager (ILOM) port. For a remote permanent connection to the Service Processor over the ILOM connection, use the rear panel NET MGT port.
Keep Ethernet cables separated from power cables by at least 60mm where possible and never run them in the same channel of the rack without segregation.
  • Category 6 (or better) Ethernet
  1. Locate the cable to connect to the Oracle Server X9-2 for Communications.
  2. Plug the RJ-45 connector into the ILOM port.
    Figure 3-4 Connecting to ILOM over the Network
    This image displays the rear view of the Oracle Server X9-2 and labels the interfaces, per the image title.
  3. Lead the cable neatly away from the rear panel.
  4. Connect the other end of the cable to the LAN.
  • Refer to the Oracle Server X9-2 hardware documentation for information about how to configure the Web browser application to connect to the console, and how to establish communications with the Oracle Server X9-2.
