Configuring Data Retention
The Data Retention page is used for configuring data retention in database for different data sources. Some settings depend on the license settings and will be available only if the associated configuration is set.
The following figure shows the Data Retention page.
Data retention is configured in days per data source. A value of 0 disables time based data retention.
The settings only affect the maximal lifespan of the data. Data availability is limited by available storage capabilities.Note:
Retention times does not affect the amount of storable data.You can configure data retention times for the following data sources:
- CPM Subscriber Data: Specifies the number of days to consider for storing the Diameter S6 transaction data. Enabled by the CPM module.
 - Media Recording: Specifies the number of days to consider for storing the RTP recordings. Enabled by RTP recording configuration.
 - Packet Inspector: Specifies the number of days to consider for storing the network-traffic history. Enabled by Packet Inspector configuration.
                           			 Subscriber Data -
				Calls: Specifies the number of days to consider for storing the call meta
			 data and signaling.
Saved calls are not deleted by this option. Saved calls must be deleted by operators. (Optional) Disable user permissions for saved call functionality. - Subscriber Data - Registration:Specifies the number of days to consider for storing the registration events.
CDR/MDRs are not supported. Data retention affects data in the database only. For deleting CDR/MDRs, use FTP to delete files after downloading.
