System Diagnostics
The System Diagnostics menu allows the creation of a report with information on the installation. This report may be requested by the support team in case of issues.
Creating a Report
A report can be created by clicking Create. This may take several minutes to complete. Afterwards, the report can be downloaded as a file by clicking Download. This file can then be sent to the support team, for example by email.
If a report exists, its creation date will be shown. It can be downloaded as often as necessary, but there can be only one report at a time; creating a new report will overwrite any existing one.
Reports are deleted around midnight UTC.
Report Contents
The contents of a report include:
- Information on the available hardware of the machine that the monitoring solution is running on
 - Log files
 - Configuration of the monitoring solution
 - Statistics about the performance and status of components of the system and of the monitoring solution
 - If the check box Include mysql dump... is checked, the report includes a dump of most of the database tables. Note that the respective tables might be huge.
 - If the check box Include mysql dump... is not checked, the report will include only minimal information about the database tables.
Sensitive information is removed before report creation, including, but not limited to, passwords, keys, and certificates.
