System Requirements
The following sections describe the hardware and software requirements for installing and configuring DPDK for Session Monitor.
The software and hardware details mentioned in this section are minimum requirements to enable DPDK for capturing high volume of network traffic. Contact Oracle Support for more assistance.Hardware Requirements
This section describes the hardware requirements for installing and configuring DPDK.
Minimal Requirements
Following are the list of minimum hardware requirements:
- Probe machine (with DPDK) (2 Intel processors, each with 8 cores, 8 GB RAM, Intel based network card)
 - Mediation Engine and Probe in one machine (at least 2 Intel processors and 24 cores in total, 24 GB RAM, Intel based network card)
Supported Servers
For supported servers, see the Session Monitor System Requirements section.
Supported Networking Cards
The following networking cards are supported:
- Sun Dual Port 10 GbE PCle 2.0 Networking Card with Intel 82599 10 GbE Controller
 - Sun Quad Port GbE PCIe 2.0 Low Profile Adapter, UTP
 - Sun Dual Port GbE PCIe 2.0 Low Profile Adapter, MMF
Software Requirements
Supported DPDK versions for Session Monitor
The following table lists the supported versions of DPDK.
Table 7-1 Table 5-1 DPDK Support Versions for Session Monitor
| DPDK Version | Session Monitor Release |
| 16.07 | Supported from 3.4.0.0.0 |
| 18.11 | Supported from 4.2.0.0.0 |
| 19.08 | Supported from 4.3.0.0.0 |
| 19.11 | Supported from 4.4.0.0.0 |
