Session Monitor Post-Installation Tasks
This section provides instructions for the post-installation tasks for Session Monitor.
Before starting the post-installation tasks, verify that Session Monitor installation tasks are completed and all components are installed. See Installing Session Monitor Using the RPM.
About the Platform Setup Application
The Platform Setup Application guides you through the Session Monitor configuration steps, including configuring the machine type, capture settings, and simple mail transfer protocol (SMTP) settings as follows:
- Accept the license agreement to proceed with the Platform Setup Application.
- The menu on the right shows your progress during configuration.
- The Machine Type page sets which licensed Session Monitor applications are installed. In the Server Certificate page, you can upload your signed certificate for secure HTTPS connections.
- Subsequent sections
configure the Session Monitor server for your network. These steps are
optional.
Except for Machine Type and Extensions, you can review and change settings at any time by visiting the Platform Setup Application at https:// ip_address /setup/, where ip_address is the IP address of the server that hosts a Session Monitor application. This URL is valid for any Session Monitor server.
- In the final step, each selected Session Monitor application is installed.
After a successful installation, the log in page appears for each of your licensed Session Monitor application.
Platform Setup Application Initial Log In
All the Session Monitor application interfaces are accessed through encrypted HTTPS connections. At the initial login, your web browser may not recognize the server and displays the This Connection is Untrusted warning message. Click Confirm Security Exception to proceed.
For information about how to protect connections to the system and avoid the untrusted certificate warning in the future, see Oracle Communications Session Monitor Security Guide.
This section describes how to configure Session Monitor using the Platform Setup Application.
To configure Session Monitor:
Changing Community MySQL Edition to Enterprise Edition
- From My Oracle Support (MOS), download the patch from Patches and Updates
section:
p28822761: MySQL Database 5.7.24 RPM for Oracle Linux / RHEL 7 x86 (64bit).
- Download the zip file p28822761_570_Linux-x86-64.zip and place it under /root or any directory on the system.
- Download the latest Enterprise edition of MySQL in version 5.7.38.
- Uninstall the Community edition of
MySQL by running the following command:
yum remove -y mysql-community-common - List the MySQL packages that may have
remained using this
command:
yum list installed mysql* - If you are running mysql community version 8.0, then run this
command to remove
mysql-community-client-plug-ins:
yum remove -y package mysql-community-client-plugins - Install the Enterprise edition of
yum install mysql-commercial-*.x86_64.rpm - Install the yum utils by running
yum -y install yum-utils - Enable the latest Oracle Linux 7
add-on's by running the following command:
yum-config-manager --enable ol7_latest ol7_UEKR4 ol7_developer_EPEL ol7_ optional_latest ol7_addons ol7_UEKR3 ol7_UEKR5
Latest Public Yum Repo has to be downloaded for enabling the repo if you have not downloaded as part of Configuring Repos and Proxies.Virtual Machine Probe Cloning
A cloned probe is an exact replica of the original probe having the same UUID as the original probe. However, each probe requires a unique UUID to establish a connection with the Mediation Engine. If the Probe Virtual Machine has been cloned, you must change the Unique ID of the probe after cloning and before connecting the cloned probe. Follow the instructions after cloning the probe to generate random UUID.
- Cloning of the probe has been successful.
- Cloned probe is not connected to the Mediation Engine. If it was connected,
remove:
- Mediation Engine details on the probe
- Probe details on the Mediation Engine
