Basics Configuration The basic configuration for the AWS instance deployment includes: Get started by completing the tasks outlined in the Launch Instances dialog box. Chose the appropriate region Specify the name as your Virtual machine name Browse all public and private images and search for Oracle Linux 8.6 Select the appropriate size of the image, and the minimum recommended shape. Figure 9-9 Launch an Instance
