Configuring Session Monitor
This step in the
configuration process allows you to configure Session Monitor settings for this machine
in accordance with the terms of your license.
On the left side of the page you must enter the number of concurrent calls
printed on your license. On the right side you must check the product extensions you
have a license to use. All enterprise customers should automatically check Media quality.
Click the continue button to navigate to the ME Connection List page.
If you do not have a valid Session Monitor license, contact Oracle.Figure 4-3 Configuration page
![Configuration page Configuration page](img/license_ojet.png)
The number of Concurrent RTP streams can cause performance and stability issues if it is set higher than the hardware and the network permits. Values above 20 are not recommended. Changes to the RTP recording setting take effect only after a restart of the system. If you have multiple servers involved in your set up (additional standalone Probes servers connected to the Mediation Engine), this setting must be set on each Probe (unless certain Probe is not sniffing Media so that RTP recording is not really applicable for the Probe). In such scenarios, the value that is set should be same on each node, on the Mediation Engine (or the Mediation Engine with local Probe), and the Probes.
