Create and Deploy OCSM on OCI
You can deploy the Mediation Engine (ME), FDP, and Mediation Engine Controller (MEC) nodes of the Oracle Communications Session Monitor (OCSM) on Oracle Cloud Infrastructure (OCI). When deployed on the OCI platform, you configure and operate the OCSM as you would on any other platform. You can deploy the OCSM to use the environment's IP infrastructure, including the private and public addressing scheme.
Before installing OCSM components, SSH keys must be generated to access the OCSM VM instances.
For more information, see Generating an SSH Key Pair on Windows Using the PuTTYgen Program.
